captainnate
Thread starter- Joined
- Apr 19, 2011
- 215
Since I'm in super slow motion with this project and I've had the boat floor out for a while, I noticed that area in front of the first rib holds a cup or two of water when it rains. That area is full of sealant goo that must be blocking the water from escaping. I store the boat outside with a cover. However, water still finds its way in. Should I drill a couple little drain holes in the first rib? Seems like they might just get clogged easy. Should I make an access hole so I can shopvac the water out? Seems like water sitting in there will cause that front floor board to rot faster. Thanks.
