Ok so weird thing today, took the motor out, started right up, idled great at the dock while I parked the car, took off we were going 18 mph as expected. Then after about 10 minutes WOT I started to hear a miss, slowed down and sure enough we were missing, went to turn it back up WOT would only give me 5 mph
. Got home, checked compression 125/128, Checked points and they are good, checked coils and they are good, looked at plugs and one looked fouled, swapped plugs tried to started in bucket and the motor will not start now, checked exciter coil and it gives me a .6 ohm reading that is the same as before this issue so should be good. I tested spark at the plug the caveman way, held the dang thing and pulled the rope, top shocked me and bottom did not. Any ideas on what to look for?
