1973 50hp Johnson starts fine most of the time.
zebrex
I have a 1973 Johnson 50esl73r Most of the time it cranks over you raise the warmer then bump the choke and it starts right up. sometimes it will crank over fine but wont fire. I am not getting fire on either coil. I need some instruction on how to test the ignition circuit and the power pack for proper operation. (then an hour later it starts fine again)
zebrex
Re: 1973 50hp Johnson starts fine most of the time.
thats exactly what I was looking for! Thank you very much. The only thing I am confused about it that the engine doesn't charge the batteries and the title of the article is alternator driver CD ignition. I was under the impression that this engine did not have an alternator.
zebrex
where is the stator? and where or what is a DVI. I know where the powerpack and the coils are.
mikegood
sorry i dont no the answer to your problem.maybe you could help me with mine though?i have same motor year everything,no u no how to change impeller or how to tell if im getting water through the system thanks
