yooperangler
- Joined
- Sep 17, 2010
- 721
I'm in the process of replacing the impeller on My 73 Johnson. It was easy enough to get most of the parts (some have been replaced with other part #'s but seem fine) The problem I'm having is that seal on top of pump housing is different from original even though same part # . The original one was solid rubber with a flange that fit inside tube for driveshaft new one is just a piece of foam basically and seems porous. Does anyone know if Johnson changed this part? Or is it possible that it was packaged wrong from Mfg. ? Thanks in advance for the help guys.
The one on the left is the original one fits on top of pump housing
Same part # as original
Here's the original before taking apart not sure if I should use this new one or not ? Thanks
