Bluewater84
Thread starter- Joined
- Sep 15, 2017
- 110
As the title says. Just replaced the head gasket and the water jacket gasket. New thermostat. Hasn’t ran since I realized what was wrong with it and fixed everything. As you can see in the pictures, I have what looks to be some type of temperature probe that goes into a grommet. I’m not sure if there is supposed to be something attached on the other side of this wire? And also, what does this wire go to? Does it regulate motor temp? It runs decent until I hit high RPM and then it begins to sputter and bogged down. I think it to be a carb issue but I’m also not sure if it’s sensing an overheat because this temperature probe is not correctly installed. Thank you for your help!
