notactjack
Thread starter- Joined
- Jan 1, 2014
- 9
Ok I needed to do a carb rebuild on my Johnson. When I tried to run things on the water muff the key would not engage the starter. I could jump the starter and get the boat running. I had a spare key switch that worked and I swapped that. I then bought a new starter solenoid from iboats and now I cant get it to crank with the key. When the key is in the on Position I have power to the "S" position on the starter. I tested the neutral switch in the controls and when its in neutral I have continuity at the switch. . My choke with operates too. Just no fire? Is there another switch that might be preventing the engine from firing? Also I checked the fuse that is near the starter solenoid.
Do I need to ground the starter solenoid?
