rhayes2849
Thread starter- Joined
- May 13, 2010
- 23
I have a 1973 mercury 1150 115 hp that gives me full rpms at full throttle but low speed. Some times it will slowly catch up and speed up. Please help.
I would check the prop. The rubber hub could be bad and spinning. Put some fingernail polish on the prop and hub to see if the prop spins on the hub. If it does, bring it to a prop shop and have them fix it for you.
+1. When you mark it the mark needs to extend from the splined brass out to the material from which the prop is made. Prop shops rehub as a regular service. However, if your prop is all dinged up, and an alum, you can get a new one on here for about $100 which wouldn't be too far from what you'd pay for a rehub. They are on sale and the Solace rubber hub props are about $40 off regular price.
HTH,
Mark
