FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1973 mercury 1150 115 hp that gives me full rpms at full throttle but low speed. Some times it will slowly catch up and speed up. Please help.
I would check the prop. The rubber hub could be bad and spinning. Put some fingernail polish on the prop and hub to see if the prop spins on the hub. If it does, bring it to a prop shop and have them fix it for you.
+1. When you mark it the mark needs to extend from the splined brass out to the material from which the prop is made. Prop shops rehub as a regular service. However, if your prop is all dinged up, and an alum, you can get a new one on here for about $100 which wouldn't be too far from what you'd pay for a rehub. They are on sale and the Solace rubber hub props are about $40 off regular price.
You mark it then go to the water. Firewall the throttle a couple of times while in the water after you get past the no wake zone. Try to get it on plane. A couple of minutes of that is all it takes.
Come back to the dock, put the boat on the trailer and take it home. When home, pull the prop nut and washer off and look at your marks. If misaligned, the prop hub is spun.
