glnbnz
- Joined
- Oct 4, 2011
- 458
Hello All,
I have a 1973 Ozark T-164 Tri-Hull Runabout boat. It has an 85HP 1975 Johnson and I did get it out on the water for 1 test run after I bought it and before it got too cold. When I bought it, it had a soft deck towards the back of passenger area (don't worry I knew about it when I bought it and don't have a lot in it). Here is an outside picture of the boat...
Here is a picture taken from the port side looking into the passenger area after removing the rotten deck and cleaned it up some:
Questions:
1. Do those stringers supply hull strength or does the shape of the hull do that?
2. There was no foam when I removed the rotten deck. Should I apply foam when I do the rebuild?
3. How tough would it be to remove the top of the boat?
4. Any other word of encouragement is welcome...
Thanks
Questions:
Thanks
