1973 Ozark Tri Hull - Deck Rebuild
glnbnz
Re: 1973 Ozark Tri Hull - Deck Rebuild
Okay I am crying uncle on finding 3m 5200 for sealing the screws down on my deck.
Is there something else I could use to accomplish that job?
Woodonglass
Did you check Lowe's? They carry it here in Oklahoma. You could also use 5min epoxy.
glnbnz
Yeah our Lowes here doesn't carry it...I did find Stainless Steel Screw though. What is 5min epoxy?
Pmccraney
Bass pro shops and academy sports both carry it. Not sure if that helps you.
glnbnz
Thanks Pmccraney...I don't have those shops near me but I am always up for a road trip :)
here is a shot in the dark , try here........ the folks that make this GREAT site possible !!
http://www.iboats.com/Boat-Parts-Accessories/dm/keywords.3m 5200
woosterken
Thanks also to you woosterken...I will check that out :)
glnbnz
I have some gellcoat questions:
1. Before gellcoating the deck do I need to scuff the fiberglass if it has been a while since I glassed it?
2. I have about 60 square feet of deck area, how many square feet will a gallon of gelcoat cover?
3. Do I apply 3 coats like paint or is there any prep work between coats?
As always thanks for the help!
glnbnz
P.S. Will I need to thin the gelcoat in order to paint it on with a roller?
Thanks again
tallcanadian
Hey Glenn, you still floating around? I've been waiting to see your great project. How's the progress coming?
Sea Stomper
Amazon.com carries 5200. 17 bucks for a cartridge.
glnbnz
Hi Tall Canadian thanks for the stop by...I moved my thread to my blog. I wasn't really getting too much response here and still wanted a record of my progress so I moved it. You can check it out at http://bnzfam5.blogspot.com
I haven't added anything for a couple of months but I will start back up again when I start the fall projects!!
