1974 Chieftain 25 "Adventurer" Restoration
Watermann
Looking good on the drive clean up although that chipped skeg stirs something in my brain. I used a saw and belt sander to smooth the OCD out of my broke skeg. :sneaky: :ROFLMAO:
IslandExplorer
old paint never dies. lol we just cover it up! more updates needed here lol.....
Haha that's right! That stuff was really on there but a good stainless wire wheel (sharper) and low amp angle grinder took it off nice and easy. Hopefully have some updates soon!
IslandExplorer
Watching this almost gives me the motivation to go outside and start yanking my outdrive.
Almost! ;)
Luckily a bunch of the worst parts of this project that I was truly dreading weren't Half as bad as they were in my head. In a way, it's good to look at it as a mountain bc once you confront it head on- you're over the little hill in no time.
I might change my tune once I'm doing the drive bellows though! šŸ˜…
IslandExplorer
Loving the transformation of the outdrive. You gonna clean up/grind the inside as well? love the pics!
Thanks! I am stripping the worst areas but bc of the age and unknown condition of the MC-1 I am not going to take it all apart to get to all of the inside surfaces.. I am just scuffing up the areas that have really solid paint on them still and they'll be painted over.
IslandExplorer
Thanks and you know, it's funny you say that bc it was driving me crazy too.. 😬 I kept wanting to weld it but I am not set up for aluminum right now. Belt sander sounds like a good plan.
Watermann
Not sure if I showed you the drive cart I welded up, makes my yearly drive pull job a breeze.
embed
IslandExplorer
embed
That is a sweet setup you made, very professional looking too! Is that a trailer tongue jack and an engine stand that you used to make this?? Very clever repurposing idea. I just might have to copy this if you don't mind.
Watermann
Yeah and I still have the plans for it too.
A = 24"
B = 24"
C = 21"
D = 4 1/4"
A & B are 2"x2" thin wall box tubing.
B should have a straight cut on one end and a slight angle cut on the other. I think that angle is somewhere in the 15-17 degree range. The exact location for the forward legs isn't critical. What I did, was, put the angle ends of the legs out far enough from the center so the far end is just a little wider than the back tube.
C is 1"x1 1/2" rectangle tube, thin wall. two pieces 21" long and one piece 4 1/4" long. Weld the 21" pieces to the short piece. These are the lift arms and are located no less than 19 1/2" from the flor. This measurement is to keep the skeg from hitting the ground when the jack is in it's lowest position.
D needs to be 4 1/4" apart so the drive will fit between.
I used 3" h-d casters. 275lb. capacity each. Put swivel casters on all 4 corners.
I also put cork gasket material on the lift arms to keep from scratching the drive.
The jack is a 3000lb weld on tongue jack (square body).
IslandExplorer
A = 24"
B = 24"
C = 21"
D = 4 1/4"
Awesome, and thanks for the detailed directions! Cork guard is a nice touch. Thinking I'm going to have to make one of these. But maybe with fixed rubber hand truck tires at front bc of my damn moonscape yard and complete lack of smooth floors in the shop.
IslandExplorer
Ahoy! Like a yellow barrel I have finally resurfaced. I wish I could post a better update but photos are not posting. The boat is -finally- being worked on once again. Gimbal bearing just arrived today...
Oops! We ran into some problems.
The upload failed because the file could not be written to the server. The site administrator will need to resolve this before any files can be uploaded.
IslandExplorer
IslandExplorer
So the revival of the project caught the attention of the admiralty and she's pushing for a different look with the old Mercruiser MC1 outdrive. Traditionally they're painted "Phantom Black" by Mercury but we are going to run the original/super old school Mercruiser look with a Spectre White outdrive and orange lower unit. This will match the boat's colors so thinking it will blend just fine. I know this is an egregious sacrilege to the traditionalists out there but we already had to leave the 100% factory look behind a while ago.
