IslandExplorer
- Joined
- Oct 21, 2019
- 605
I'm thinking since they look good I'm going to just run em as is with fresh oil and do a real early oil change after the first couple short runs to see how the fluid looks. Figure that should be telling. Hopefully the lower unit gears and beaeings are in good shape too.Yeah those guts look great, I've seen some wrecked upper gear sets.
Nothing special on the hose. Standard coolant type hose.Anyone know if the water hose is a special type of hose or is it just plain old 5/8 automotive coolant line?
I don't want to wait for a shipment if it is just 5/8 standard stuff. Hoping to get the transom plate back on ASAP.
Awesome, thanks!Nothing special on the hose. Standard coolant type hose.
Luckily I think I still have the shaped hose for the inside portion, believe it had a rubber plug in it to change the diameter if I recall but haven't located it just yet.The raw water hose between the transom assembly and the outdrive isn't anything special, just might be thicker walled to keep from kinking. Be sure to get the shaped hose for the inside after the pass through.
Thanks! Glad to be back too my friend, was away from this project far too long.welcome back brother. looking good......
My supersport v5 was repowered to a 5.7 as well. Similar to IslandExplorer's mount except it sits on a couple of spacers to get the engine height right.I'm curious how those engine mounting points on that boat are constructed. Most of the time we only see the 3.0L inline 4 and inline 6 front engine mount construction on these tinny boats with sterndrives.
More detailed photos of that would be appreciated if possible.
