1974 Mercruiser 140 4 cyl
EEOCRAM
Idles fine in the driveway and on the water. Give it full throttle and it sputters and backfires from the carburater. Won't go over 10 mph. I changed the points, condenser and plugs. Put HEET in the gas tank with new fuel and stabil. Sprayed carb cleaner in the carb and still have the same problem. Should I replace all fuel filters and fuel pump?
JB
Re: 1974 Mercruiser 140 4 cyl
Howdy, EEOCRAM.
Welcome to iboats. :)
First lesson: Mercruiser is not an outboard, it is an I/O.
Moving this.
Don S
When you installed the new parts, did you confirm the point dwell, then check the timing, then readjust the idle mixure and idle speed?
Spraying carb cleaner on and in a carb makes it look nice, but does nothing on how it works.
EEOCRAM
1st I don't see where I indicated mine was an outboard. 2nd found out that the ignition wires were not hooked up correctly. Once I fixed, set the points at .022 ,cleaned the carb, put in some HEET and stabil, took out on the water worked like a charm. Very happy, going fishin in the mornin. Stayin on the river all day. Just got the boat last Friday.
Ayuh,...
I gotta Guess that JB found your thread in the Mercrury Outboard forum,+ moved it here to the I/O forum.....
Well,..... We can only Assume that you know what you're doing,+ Did it Right....
With the Info provided by yourself,... You got some Very reasonable Answers.....
Ayuh,...... Good Luck Fishin',...
