1975 25 hp throttle
Starboardlean
Old evinrude resurrection has gone well. One quirk however. When advancing the throttle, if you go to far, the roller can fall off the other side of the ramp( ?timer base?). What to inspect/ repair to prevent this?
F_R
Honorary Supreme Mariner
Lessee, If I'm thinking correctly, the magneto armature plate rotation is limited by going up against the vertical shifter interlock bar. So, question becomes, is the shifter interlock bar installed and working properly?
Starboardlean
FR....you nailed, I was wonder what the bar was in the bag of parts. Throttle fixed. Thank you. Another old Evinrude revived
