1975 25hp shifter
guajiro0192
Hi all. I am having a problem changing gears on my 25 hp 1975 evinrude. I start the engine in neutral then put it in gear. When I try to take it back to neutral, I have to turn the armature back so that the shifter can go back in neutral. I also have a part that looks like it would lock out the fly wheel. 05-07-10_1959[1].jpgIt looks like a plastic part that goes in back of the gear shift. I think that it might be broken. If so, where can I find one? Any advice is appreciated. I tried to attach a pic. I hope that it worked.
guajiro0192
Re: 1975 25hp shifter
Thanks so much. That looks like it. What is it supposed to do?
Daviet
When it is working properly it keeps you from starting the engine in gear.
guajiro0192
Thanks for the info! I am having trouble shifting the gear lever back into neutral. If I take the cowling off and advance the points housing (i think that is it) I can get it into gear. If I dont the stopper will not allign. Is that due to the lockout lever also?
