1975 50 hp evinrude outboard rev limiter Tachometer question.
chad913
I have a 1975 50 hp evinrude ob thats rebuilt brand new and i don't want to over rev it. Can Anyone tell me a good tachometer to use and were to hook it up? thanks
emoney
Re: 1975 50 hp evinrude outboard rev limiter Tachometer question.
There's a ton of different tachs on the market so I'd find one that's reasonable and will easily install and use that. Treat it pretty much like a new one for the first 10hours and you'll get plenty of use of it. Good luck.
chad913
were would it hook up on the motor? 50 hp evinrude ob
jbjennings
I believe the tach would hook up to the gray wire coming out of the powerpack if that motor has one. Just curious, why are you worried about over-reving it? Are you suspicious that your prop pitch is wrong?
JBJ
chad913
just for the peace of mind.
FillupD
I installed a tach on a 1973 50hp evinrude and it connected to the gray wire that was "dead ended" in the control box. Look for a gray wire with a loop at the end of it that doesn't go anywhere and connect it to the appropriate tach post. Tachs come with pretty good install instructions.
I believe the gray wire originates from the yellow wire from the stator at the connection terminal by the power pack? Not positive though.
chad913
ok thanks, You guys know were to get a good tach at a far price?
dew2
Google TinyTach I just bought one for $34.99 great little tool!!
chad913
Yes that is a great link! I love this iboats forum. were is the safe MAX on the rpm's? 7000?
chad913
ok running into a problem.... What kind of tach will work on my motor?
