steveo32
Thread starter- Joined
- Mar 15, 2008
- 60
Took the boat out this last weekend and had a blast on the lake but ran into a couple of problems. For some reason the bilge wasn't pumpiing out the water that accumulated from getting in and out of the boat while tubing. Bought a new one and shortened the tubign and the new one seems to work fine. Also because the boat took on quite a bit of water meaning the bilge was full and that means the tanks under the boat floor where full also cause I have two holes on the sides inside the bilge that go into tanks under the boat floor.
So the boat stalled out a couple of times while taking off wakeboarding. I assume this is because the carbs need to be cleaned and the added weight filed up the carb bowls and flooded them. So I am going to clean them out and buy the carb kit. Also the bottom cylinder coil has a hair line crack in it, I was just wondering if that may have had something to do with the stalling also. I have already ordered a igniton coil just waiting for it to be delivered. Can I still take the boat out or am I asking for trouble and a paddle trip home?
