Garner51
- Joined
- Jul 12, 2023
- 41
I’ve got a 1975 sea horse I got from a “friend”. First I had to buy the top coil for the motor as someone had took it. I done the routine check the compression I have 90 pounds on both cylinders so I continued with the carburetor cleaned it up nice and I pulled my plugs out and checked them. They gave a nice blue spark so I threw it in a barrel and plugged up the fuel tank tried to start it Hense on tried to start. Nothing… well I done my troubleshooting once again.. I’m getting spark I’m getting gas. I just don’t know if it’s at the right time so… I done some research and found this.. (I’ll attach pictures )I done exactly as it says. But I’m still not getting it to run. I mean. I cant even get it to hit off starter fluid being sprayed directly into the neck of the carburetor is there something else I’m missing or doing wrong. *side note my flywheel has the I’m assuming timing marks on the underside and the armature does too but mine doesn’t line up it’s almost like mine is backwards but how when the crescent key IS NOT BROKE. I’m by no means a boat mechanic but I know a little and I will say I’m so sorry if I ramble or seem to ask a dumb question this to me is just baffling….
