In an earlier thread, I determined my new-to-me 1975 Mercury 200 (S/N 4148487) was worn out. It had only 60 PSI compression in each of its two cylinders. So, I decided to purchase a powerhead on eBay that claimed 115 PSI on each for $80 + $30 shipping. For posterity, I'm going to document what I am doing to swap the powerheads and hopefully have an operational motor before the weekend. I intend to take to boat on vacation in 2 weeks, and would hate to get stranded with the family. Please chime in if I am doing something stupid as I have not worked much on outboards before.
The online manual I am using is found here:
http://boatinfo.no/lib/mercury/manuals/mercury_1965-1989_2-40.html#/0
I have a Seloc manual coming, but it has not yet arrived.
Also, if you do things right, you can get parts diagrams here:
https://webapps.brunswick.com/literature/literatureSearch.do
I thought it would be a good idea to replace the crankshaft seals while the powerhead is out, but I am now thinking that is a bad idea. On the flywheel side I can see the edge of the seal, but it looks hard to remove. I'm also not sure if I need to pull the small cover over the bearing or not. The seal on the crank side is totally hidden. The manual does not cover simple procedures like replacing the seals, so the only instructions I have are complete block disassembly, and that looks too complicated. I see no evidence of leakage, so I am going to assume the seals are good.
