1975 Starcraft Mariner 18'
yooperangler
Re: 1975 Starcraft Mariner 18'
Huron yeah the one photo is a dual battery switch only has the cables for one battery though that part of the wiring is actually necessary anyway:) Much of the rest of it is just senseless to be honest P.O. must have been running disco lights and a generator or something idk;)Maybe some of the switches turn the lights on in his house :confused: Teamster that is actually a good idea any thoughts or pics of how that might be done would be helpful I had just planned on welding her back together but would definitely make sense to be able to get it in the garage again:facepalm:
yooperangler
Got out in the garage today and started a bit of demolition started tearing the extraneous crap off the port gunwale (had taken a few things off already ) aside from to many screws that were too long and too rusty was pretty straight forward.
P.O. Had plenty of rusty sheet metal to use for backing under down rigger mounts
Bow rail was a bit stubborn some of the set screw wouldn't come loose but a little persuasion and it came apart:rolleyes:
yooperangler
Anyone need one of these?? For sale cheap!!
Or this ? I don't know if its a rod holder? Flag pole bracket? something for a trolling motor?
Finally noon time to switch gears:D
yooperangler
Why are all these screws soooo long??:mad: When I put it back together I'm using at least 4" long hardware to make it even harder for the next guy:)
yooperangler
Found an extra light under the bow kind of hard to lay down and read under there though
Missing a red lens horn worked though
A quick brushing and a little help from the shop vac and port gunwale is ready for prime and paint ( Insert grumbles and curses here ;))
yooperangler
Repeat for starboard side
Realized most of the second floor wasn't fastened down so decided to eliminate it
yooperangler
Don't try this at home boys and girls as believe it or not the snow and ice tends to add a bit of weight
No wonder this stuff wouldn't melt it even defies the laws of gravity :)
yooperangler
Starting to feel like I'm getting somewhere
Note to self " Step stools and ceiling fans do not mix":facepalm: I have a headache
Mini live well ? Hoping that foam wasn't poured in through this hole seems loose and popcornish so probably just the original white stuff.
This doesn't seem right to me floor is cut out around supports on both sides close to bow seems it should be higher and fit side of boat better :confused: Possibly someone replaced it before??
yooperangler
Found a screwdriver
Aft part of upper floor required a little more force
But in the end I prevailed!! This piece was really heavy and in retrospect I should have called in reinforcements
yooperangler
Disclaimer " No step stools were injured during the filming of this procedure" (my back is another story)
Slightly used plywood for sale
Found another hole and a quarter in the stern this project is really starting to pay off:D
Finally lost my patience with rusty screws!!
yooperangler
Is it just me or is there something wrong here ??? Hadn't noticed controls were backwards until now:mad:
Maybe I'll just put the console in facing the stern ????
yooperangler
At least I finally made a little progress :cool:
Swept up the worst of the mess. Hoping floor dries out now.
I figured out why this boat is such a mess, It came from the wrong part of Michigan pic is hard to read but says Lansing , MI you down state guys should stop sending your problems to the U.P. ;) Anyway time for dinner might get back out there later though..
mark1961
Ensign
If those deck panels are still mostly intact......make sure you keep em for templates for the new deck if you're not changing the layout too much.
yooperangler
Thanks Teamster those cabelas guys think of everything:)
yooperangler
I have to work midnights tonight so figured I would get started early and see if I could make a little progress before time to eat shower and grab a nap. Is it just me or does anyone else have trouble with pics getting out of order when uploaded to photo bucket ?? Mine seem to end up last first and middle to first from the top strange...
Got out in the garage around nineish decided to start by removing a bunch of snaps all the way around boat from a boat cover.Took about half an hour to find the right drill bit only about 10 minutes to remove them all.
Hole looks a lot bigger than it is.
Figured I would make you guys happy and remove at least some of the gunwale trim. A little drilling and a quick tap with the dead blow and off comes the corner (different size rivets here so of course more time hunting for a bit)
A little ugliness under the corner and transom does seem slightly mushy but no real surprise there..Can't remember from all the other threads but is plywood transom stock or ???
My method of rivet collar removal clamp in vise and reverse drill wallah:D
yooperangler
Port side inside gunwale trim is history
Then the bow
Had to remove mfg tag with starboard trim noticed it says rated for 130 horse and am sure I heard 115 somewhere... Doesn't matter I guess as I'll probably stick with the 65 for now.
yooperangler
Starboard corner came apart same as port.
Just as ugly underneath only thing notable is gunwale extends a little longer on this side for some reason ?
Hit em quick with a wire brush and shop vac again not looking too bad.
yooperangler
Time to start on what I really planned on doing today now that I pleased the masses:) Removing bow platform.
There's a rivet up there somewhere
Found it !!
A little forceful negotiation
And presto its a convertible.
