DWbaseball
- Joined
- Aug 25, 2020
- 136
Good call out. Likely not haha. Also there are metal contacts that might be up against the hullLooking good. You going to have enough room between the hull and the side board for the speaker to fit?
SHSU
I did not glue these but I thought about that halfway through and could or should have. I think it will be fine for sideboards where I have it pulled tight, stapled good, and riveted. But you might want it glued for seats where there will be lateral forces and a wider run.Looks good! I’ll be covering my open bow pieces with vinyl next week hopefully. Did you use any glue?
I used 1/4" batting on my SS panels just to add some cushion for for the vinyl after seeing how easy it gets injured on my Chief with just the plywood underneath.I did not glue these but I thought about that halfway through and could or should have. I think it will be fine for sideboards where I have it pulled tight, stapled good, and riveted. But you might want it glued for seats where there will be lateral forces and a wider run.
I am about to cover my bow seating panels with vinyl. I was not going to use any foam underneath. I asked about this on an upholstery forum and most said to add 1/4” foam for the same reason you said. Now I’m really wondering if I should…..I used 1/4" batting on my SS panels just to add some cushion for for the vinyl after seeing how easy it gets injured on my Chief with just the plywood underneath.
LOL, now I see itSHSU-I can see what you see but it's not a pencil. Just a rusty flathead that I was using on the hose clamps.
