Good stuff.Here we go got these glued up and a weekend of hot weather ahead of me.
I got advice from my BIL who is a carpenter and his recommendations were to go () and to clamp it once I started adding weight so there was no shifting. View attachment 366104
Looking good. You going to paint the splashwell or leave it bare?
SHSU
Cant believe I didn't get any pics of the knee brace that I have temporarily pop riveted in and had the transom wood slid in for a test fit. Looks great, only minor trimming needed. Felt super solid.
The grey stuff on the hull is regular jb weld with a tube or two of jb marineweld thrown in (white). I am using this to thinly skim/sand over any minor putting or corrosion that I found. The idea is that the aluminum brightener (acid) prep should kill any ongoing corrosion and then the jb weld fills in any pits so that if I have water in the bilge in the future, water can't pool in the pits and allow corrosion to restart.Looks like good progress to me!
What's that dark gray stuff on the inside and outside of the hull?
It was just warm enough that I felt like I could do some spray paint today, this splashwell looks better with a second coat of blue but will probably always show some spray lines. Maybe someday I will try to brush it out smoother but it's gonna get installed like this.
When putting the flooring back together, make sure to use wood joiners under the deck between the sheets. You can screw into them and it will help keep the floor even and prevent sheets from warping different ways compared to the partnered sheet.
Plus if you are doing post seating, this is the time to also add another sheet underneath to help strengthen the are the pedestal will be installed.
SHSU
