75-JOHNSON
Thread starter- Joined
- Jul 2, 2009
- 55
hello all,
i recently got a boat with a 1976 75 johnson engine from my uncle, and the boat had been sitting for 15 years without running. It started up fine and after replacing the fuel we took it to the lake and tried it out. he says the engine never did run right and sure enough it would not open up. the throttle linkage appears to be opening all the way but it wont get up on plain and the max rpm i can get is only about 2000. however out of gear with the warm up leaver it will get to about 3500 rpm. i felt the tops of the three heads and they all seemed to be the same temperature which leads me to beleive all three pistons are firing, or could this be just because of the circulating warm coolant? any help, information or thoughts about where i should start would be greatly appreciated.
thanks
thanks
