1976 ford 302 no fire
Fatbs
I just rebuild my 1976 ford 302 and now i have no fire. I just started messing with it again today. I am almost sure all the ground wires are hooked up. I am going to start at the coil, because the boat did sit up for 20 years. Any other suggestion would be great...thanks
Bt Doctur
Well if you installed and gapped the points correctly and set the dist in correctly and set the firing order correctly and have 12v at the + side of the coil it will run
Make sure your points open and close as the distributor rotates
clean your points. pull the nail file from your wifes purse, run it thru the points twice. then set gap to 0.018. adjust dwell and timing and she will fire assuming you have proper compression and fuel.
99.99% of the time its never the coil
Ayuh,..... That can't be repeated, often enough,.......
Millions of perfectly good coils are tossed into dumpsters every year at boat launches,....
Just because it's really easy, 'n fairly cheap to replace,....
