Yes, your float/needle is not closing in at least those two carbs.
Just try again. You will get it. They can be finicky.
I am not so good at explaining over the net. Did you use an OEM kit or a sierra?
There are several reasons why they may not be closing.
1: poor adjustment, personally, i cant remember the last time i had to bend an oem float.
2. Float upside down if possible on your model. Some can go, some cant be installed upside down.
3. Dirt or debris in seat.
4. Missing or wrong seal between carb body and seat, if applicable.
5. ...
Good luck, if i am not explaining this well some one else may ba able to do it better.
