Re: 1976 Starcraft Supersport 16'
Good work getting the Motor and trim mounts installed... They were kinda a PITA when i did mine as well... mostly because it took me to long to replace the transom...
lol.. Forgot how it all went back together. WHUPPSY! so there was some trial and error...
Did you pull the trim pump from under the splashwell when you pulled it and clean it up as well? Also where is it mounted? center?
Ted
I removed the pump when I took the motor off, it was mounted under the splashwell (right side I believe). I was definitely a bit finicky figuring it out, but I was able to make it work. I haven't done any real "clean up" on the pump it looks pretty good having been in storage for the last year. I would like to change out the fluid and start fresh before installing it back under there.
Last night I was able to get the rams installed and the hydraulic lines attached (sorry no pics). The only problem that I see is they need to be routed properly from the pump in order for it to work. I put the fittings on the rams, and tightened them loosely. They will need to be rotated to accommodate the orientation of the lines entering the pump, so I didn't kill em off yet.
Any thoughts or suggestions on the easiest way to do this would be appreciated. Ideally if I mounted the lines to the pump before putting the lines through the access holes in the trim brackets it might have helped. Except the access ports would then need better access, I would have to take the brackets loose in order to get the lines under them.
All in all everything is working well, it funny how everything is dependent on something else when it comes to putting this back together. I'm pretty sure we looked like a bunch of trained monkeys taking it apart.
