1977 115hp evinrude starter
tlflash
bought this motor and am trying to start it turn the key the starter spins but dont go up and engage the flywheel. and how many rpms is it suppose to spin? battery has a full charge is it a starter problem?
Solittle
Re: 1977 115hp evinrude starter
First remove all connections from the starter and the battery. Sand connections bright clean. Take the battery to Sears or womewhere & get a load test. Put a light coat of grease on the surfaces of all connectors and reconnect. If that dosen't do it check the solonoid. Also clean the shaft that the bendix gear rides on & rotate by hand to make sure that it is free.<br /><br />Starters do go bad but it is usually the other stuff. If your starter is bad take it to an electric motor repair place rather than buying a new one (big $$ for new).
tlflash
thx cleaned it all out still wont engage guess ill have it looked at
Mettaree
tlflash: Can you manually move the bendix gear up the shaft to the flywheel? If you can, check that it spirals up the starter shaft.<br /><br />Fair Skys, Smooth water
tlflash
yes i can move it. if i hit the key and push on the bottom of the bendix it goes right up other than that it just spins i cleaned the shaft all up it looks fine
vano6990
tlflash,<br /><br />I just purchased a 1976 ranger bass boat and had a similar problem with my mortor starting. Have you replaced the starter solenoid?
