Re: 1977 Cruise Boats Restore
Now onto the fiberglass work. I had never done fiberglass work before. I am however very handy, crafty, works well with tools and unafraid to tackle DIY project like this. (I am not humble though
) So I broke down the different parts of the boat that would need to be glassed ? transom, stringers and deck. After much reading, researching and talking to the pros, I decided to go with one layer of 1.5oz CSM over the transom and stringers followed by a layer of 1708 biaxial cloth. The deck would get a layer of 2oz CSM on the bottom and the top. The original manufacturer only used a layer of CSM and some woven roven over the stringers. The 1708 will be much stronger and easier to apply. The transom is roughly 3? x 6? and the boat is roughly 17? long. So here is what I calculated;
Transom:
1.5 CSM - 6 ft x 1yd/3ft = 2yds + 1yd (fudge factor) = 3yds
1708 - 3yds + 1yd (fudge factor) = 4 yds
Stringers:
1.5 CSM ? 12ft (stringer length) x 1yd/3ft = 4yds x 2yds/stringer = 8yds
(Since I cover two stringers with one piece by splitting down the middle I only
need a total of 8yds)
1708 ? 8yds + 4yds (extra width for tabbing) = 12yds
Deck:
The 2oz CSM is 50 inches wide. The pieces will run crosswise or abeam so the linear length off the roll will run port to starboard and the 50? wide part will be running for and aft. - 17? (boat length) x 12in/ft / 50in = 4 pieces needed on each side of the deck running stern to bow. Since the deck is approximately 6ft wide that makes 6 ft x 4 pieces = 24 ft x 2 (top and bottom) = 48ft x1yd/3ft = 16yds + 2yds (fudge factor) = 18yds ( I know I could have used less here since the bow tapers and is not a full 6?, but for simplicity purposes I used an equal width)
So the totals:
1.5 CSM = 3+8 = 11yds
2oz CSM = 18yds
1708 = 4+12 = 16yds
Polyester Resin: I took a guess based upon threads that I read and figured 8gal would be a good starting point. (I actually used about 11 gal total.)
Other stuff: Cabosil ? 2 ea of the 5qt containers
Microspheres ? 1 ea of the 5qt container
Milled Fibers ? 1 ea of the 5qt container
1/4" chopped strands ? 1 ea of the 5qt container
MEKP ? 16oz
1Qt containers ? 5
2.5Qt containers ? 5
5Qt containers ? 2
2 ea of the fiberglass rollers (3/8?)
I got all of my supplies from US Composite and it ran around $650.00 including shipping. I also bought some additional resin (3 gals) for another $90.00.
Now that the math drill is over, let?s get to work. I first started with the transom and laid out a piece of CSM and used a Sharpie to mark the cut out pattern. Once that was done I mixed up about a quart of resin. I used short nap 6? paint rollers to apply the resin and wet out the glass. Chip brushes also work well in small areas or in corners and such. I applied a coat of the resin first to the wood and the hull around the transom where the glass would be. I let the wood soak up the resin for a few minutes and applied some more to the transom wood. I then placed the pre-cut piece of CSM on the transom. The tackiness of the resin will hold it in place. I then used the roller to apply more resin to the glass until fully wetted out. Make sure you keep your roller wet with resin because if not it will draw resin back out of the glass as you go along. Once you are done, wait and monitor the curing of the resin. If you mix the resin according to the US Composites instructions you will have a good 20 minutes of work time. Make sure no dry spots form under the glass as it starts to cure. If you see some drying add a little more resin to that spot. Continue to do so until the resin starts to ?kick? and then let it go. Key areas to focus on are the edges and inside corners and to make sure those areas stay firmly down and fully contacted. I then moved right onto the 1708 layer. If you have multiple layers you can go one after the other while the first one is still tacky. This is actually preferred but not always doable depending on the orientation of the lay-up.
This is the general pattern I used for the CSM and 1708 on the transom. It extended beyond the edge of the transom and I cut out where the stringer were to create a tabbing to the hull.
Here is a pic of the transom all glassed in. Notice the tabbing onto the hull side and bottom.
