Re: 1977 Cruise Boats Restore
After the basic well was in, I added a piece of CSM along the inside rear edge of the well to re-enforce it and cover a few small cracks and such. I also re-attached those transition caps at the top of the transom as well as cover the top of the transom with two layers of 1708.
Now once that was all done it was time to get serious on the prep. I first wiped the entire boat down real good with some de-waxer. After that I gave the entire boat a good sanding with 150 grit paper. After this I vacuumed off all the dust so I could better see where all nicks and gouges were. I mentioned before that all of the lager holes (greater than 1/8" dia) were glassed from behind to give the filler material something to hold onto and back against.
Here is a pic of the hull cleaned and first sanding. Those original decals were a total SOB to get off.
There were also a lot of surface gouges in the hull at various spots above the water line. Once the hull was sanded, I wiped everything down with acetone and proceeded to fill all of the holes and scratches. For filling I used Evercoat Formula 27. I could have used a PB mix but honestly this stuff is very easy to work with and is ready for sanding in 10-15 minutes. You do have to work quickly but once you get the hang of it you roll right along. To make it a structural filler I added ?? chopped strands or milled fibers as necessary. The large gap along the splash well joint I used the chopped strands.
One thing I do want to mention and that is this whole filling sanding and filling and sanding and sanding and filling and sanding and sanding...etc, etc,etc. is a process. Start with the spot filler first and use that until until there are fine lines or shallow scratches left to fill. Then switch to a glazing compound for the final fairing. Evercoat also makes a good glazing compound as well. Also as you sand between fills, use finer grits in the sand paper you use. Also don't just sand the fill area but rather the entire boat. Yes this means you WILL be sanding one heck of a lot. It is painful but necessary. Once everything was smooth and even, I vacuumed off all the dust, wiped the boat down with a tack cloth, wiped the boat down with actone and then once more with the tack cloth right before appling the primer.
