1977 Silverton Flybridge Restoration- PICS & VIDEOS
LorenHaus
Re: 1977 Silverton Flybridge Restoration- PICS & VIDEOS
Pulled the swim platform off Tuesday. I finished sanding it down today and still need to patch a small hole that has some wood rot starting.
2012-11-28 08.45.45.jpg2012-11-28 08.45.54.jpg2012-11-29 08.50.42.jpg2012-11-29 08.51.03.jpg
saginawbayboater
Loren that swim platform has really come to life. Do you have to sand in between the open slots by hand, or is there a better method?
Thanks
SBB
LorenHaus
Applied the first coat of Epifanes today before my workday started.
25thmustang
Looking good! Which Epifanes did you go with? Did you thin your first coat or right out if the can?
LorenHaus
Thanks! I used the same Hi-Gloss Epifanes you did. I just used it strait out of the can for the first coat. Plan on using thinner for the remaining coats.
LorenHaus
Swim platform before/during/after
25thmustang
It's expensive stuff, but looks great when its on there! Good progress so far.
LorenHaus
Finished priming the engines and painting them today with hi-temp duplicolor. Now its time to start painting the bilge.
LorenHaus
ooooo shiny :) Just finished degreasing, sand blasting, priming, and painting the other two valve covers today and clear coating all 4 of them.
saginawbayboater
Sweeet!!!!! looking Great!
Nice Job Loren
25thmustang
That's going to be one clean engine room! Will be perfect for spotting any potential leaks, but may have you spending more time in there with a rag and polish!
LorenHaus
Thanks! A clean engine room means you can spot a problem or leak immediately before it becomes a nightmare. I think we're both of the same mind. Not to mention, for some reason it makes you feel your engines are more "reliable"....knock on wood lol
LorenHaus
Finished priming, painting, and clear coating the port engine bolt-on hardware (and the starboard valve covers and intake manifold).
Also started varnishing the flybridge steps. The steps were worn badly so the ridges on the steps were completely gone. I mighta cheated and used a black paint marker to make some lines :rolleyes:
LorenHaus
Paragon V-Drive trannys primed, painted, and clear coated with hi-temp engine primer, engine paint, and engine clear coat.
Side of 318 block & oil pan
25thmustang
Looking great, also your trick with the black on the treads is a good idea. Will probably help to hide the stuff that builds up in there too.
LorenHaus
Thought I might share the video of a Marine Power 6.2L LSA Supercharged engine project our company just completed for a customer. It has a Bravo III XR attached and a HP transom. This is what has been tying me up during the day for the past couple months:
fat fanny
Wow! I love that clean sound. What was the top end on that run? I saw vid this mornin on the worlds largest outboard 557 I believe basically a cadillac engine ontop of a lower end on steroids one of them pushed a 30 footer to 65 with no issues.
