1977 Sylvan Sea Monster Side Console Rebuild
oldrem
You better slow down or you're gunna have to splash her pretty soon!!!!;):faint2::eek::D
I wish Mike - but not enough time to get everything done before the snow flies. Hoping for an April or early May splash. - Eric
oldrem
Made an ignition switch plate Wednesday night and took it to a local engraver yesterday with a drawing of how I wanted it. It was done today already, so I picked it up and brushed it. I missed two small scratches that I didn't notice before the photo, but took those out right after.
sphelps
Switch cover looks great ! You gunna paint or color the engraving ?
Bilge cover is pretty nifty! That will keep the catch from flopping down in the bilge :D
oldrem
I darkened it some later with some citrus, but will probably use some black laquer or enamel to make it pop better
BWR1953
The switch cover looks great! And I'm going to copy your bilge cover. Very nice! :nod:
oldrem
Thank you. The cover is 1/8" woven stainless mesh with some trim lok vinyl edging around it. I'll support it with some aluminum angle.
oldrem
Watermann - I'm marking my rivet points for the deck so I can get the countersinks cut before OTF. Am I over engineering again? In the center two smaller panels I have 32 marked with a spacing of about 10 inches on average. I want it solid, but don't want to go extremely overboard either.
Watermann
Matching the deck rivets up the same distance as the ribs is well enough.
oldrem
Thx Watermann.
Kind of a boring day today pulling and replacing the deck panels so I could measure and mark for best rivet placement. That took me up to when the Admiral wanted me to sit down for dinner.
After dinner I drilled the first 46 holes and countersunk all but 8 that were too close to the sides for the portable press. Will get those when it all comes out for the pedestal supports and OTF. Definitely going to need a good vacuuming and blow out when I'm done.
By 6:30 it was too dark to use power tools. I really need to bring my work lights home to work any later.
oldrem
If you just want to color the lettering, maybe a Sharpie China marker?
Tried pretty much everything I could think of. The engraving just isn't deep enough to keep anything I tried in it once I clean up the surface including permanent marker, shoe polish (suggested by the engraver) and enamel. Think I'm going to have to live with it.
zool
Looking good rem!
I think if u use black caulk to fill the engraving, then take a thin cloth wrapped around a plastic razor or putty knife, you may be able to scrape away the brushed areas keeping it flush, leaving the letters filled. Just a thought.
sphelps
Looks really nice ! Maybe spray with flat black ..Let dry then lightly sand with fine paper leaving the paint in the text ..
use a flat block to keep the paper as flat as you can ... Just a thought ...
