Re: 1978 16' Starcraft SuperSport Resto
Um, skills? I have no previous or special skills going into this, learning as I go like most of us here. I'm not using an air chisel, but rather an air hammer. I have read of people using air chisels with the correct bit though. Some have said you risk work hardening the rivets with an air chisel because they hit so fast, but the rivets in our boat are "soft alloy" and won't work harden like the "harder alloy" ones will. You can pick up a cheap air hammer which I did at ATS for $85. It's how most airplanes and how your boat was originally put together. Have you guys seen it done? It's actually incredibly easy. The air hammers have a "teasing" trigger so you can start slow, and it takes literally less than a second to set the rivet. I did some practice with some scraps and after doing 3 I realized there is nothing to it. I would think you would have a better chance of missing the rivet with a hammer and how's that going to look on your hull? Before this the only riveting I ever did were "pop" rivets. You guys are way over-analyzing this. IMHO.
