1978 470 - What is leaking here?
kanada
Hi all,
The engine has a heat exchanger. Is this antifreeze or raw water leak area?
this is on the end of the exhaust manifold. Is it called the exhaust riser?
thanks,
KaNaDa
jerryjerry05
Re: 1978 470 - What is leaking here?
Looks like raw water.Drain the system,loosen the manifold and look inside to see if there is rust/ corrosion inside.Check the plugs for rust or water.Your gonna need a new riser gasket.So remove the riser and see if it's leaking into the manifold.J
