1978 Blue Fin Sea Hawk Project
badbarracuda
This is my first thread. I will try to track my progress and welcome feedback as well as advice. Just picked up this Blue Fin. The floors were soft and the Console as well as interior panels were in need of replacement. I am getting great ideas and advice so I hope this will benifet others. I gutted the floors Foam as well as most of the interior. Next step will be to get 3/4" Marine Grade plywood and cut to fit epoxy both sides as well as edges with 2- 3 coats. Just picked up .875-1" Aluminum Rivets from McMaster Carr part # RAA816 25 pack ( KB-84953140 ) I am going to add some support to the center stringers as well as cut and refit closed cell foam on port and Starboard sides I am leaving the center open for drainage as well as some storage and additional bracing. Stay Tuned......
Re: 1978 Blue Fin Sea Hawk Project
Ayuh,.... Welcome Aboard,.... Nice project,... I'll move this to the drydock for ya,...
See ya there,.... ;)
badbarracuda
Just picked up this used center console used. Going to wet sand it, fit it up for new electronics steering and some guages. I just have to figure out how to flip the throttle around to work on the Console. It's mounted on the Gunnel.
lokonn
Looks like a great project. From what you know of the boat was it always a center console? I have no experience with center consoles, I assumed all of power, steering and electrical lines were run under floor to console. New console looks like a good find. Making good progress.
badbarracuda
Thanks! From what I know yes it always was a center console, odd with the throttle mounted on gunnel. Steering and electronics were run thru the floor. The throttle cables were run along the gunnel. At this point I want to get the floor & floatation prepped. Then I will worry about seating and console braceing. I like how you stacked your foam, I think I am going that route. I think I am going with a Navy Blue or even an Ice Blue to replace the green. I also think I like the Natural Vinyl.
jbcurt00
Welcome to the iboats dry dock, tin division
Looks like a great project,
Best of luck making this BlueFin YOURS ;)
badbarracuda
Thanks! Just started reading the '60 Glastron thread.... very nice project!
jbcurt00
Sorry, but don't over expect over in the FireFlite thread. It's still w/ me, but has been relegated to not now, or next :rolleyes:
The Duracraft is coming along though. Stop by anytime........
badbarracuda
I am getting ready to tackle the flooring. There is thin bracing to mount the flooring to I was thinking about beefing that up with more aluminum bracing. Any thoughts ? I am going with the 5/8" marine grade ply I already picked up the Aluminum Rivets ( Thanks For the info Lokonn ) The closed cell foam was in great shape had some brown but I tossed them I am going to pick up some more closed cell foam as wenn as lay down some pvc for cables and eletronics. I will try to post my progress.
lokonn
Good to see you back at it!
jbcurt00
That thin strip is only to keep the edges of adjoining sheets of decking (flooring) aligned & even. It's plenty strong enough to reuse, no need to get thicker. In some project that are 'pre-gutted', the strips are missing. Since there are cut-off's left over from cutting the deck, some use rips of plywood along the edges to join sheets to each other.
classiccat
Cool Project! They're good boats :D :cool:
Do you have anything creative planned for the steering on this ex-side console?
attachment.php
badbarracuda
attachment.php
As far as I know this was a wooden center console boat. The console was rotted but the steering cable and electronics were run through the floor. The throttle cable however was run up under and mounted on the starboard side. I am going to move everthing to the new console replace the steering cable ( it is locked up ) . I think I located a power trim unit to add.. I want to replace the bulky seats for a lean post and I would like to go with a cooler seat in front of the console. I want to redo the bow area with a storage/ casting deck. I plan on using this as a bay boat.
badbarracuda
Finally back to post some progress! Started sanding down the Live well. I pulled the Groovy 70's print off. Taking my wife and Daughter to the Boaters saftey coarse this weekend and next. My daughter has caught Fluke Fever! Hoping to cut and fit up the 5/8" marine plywood. I am a little nervous about coating it with the resin. I think I need the temp to stay above 60 so It cures. Any thoughts?
badbarracuda
Anyone have ideas on paint for the topside of the boat I want to get rid of the green and go Navy Blue as well as Navy Blue on the console. I was wondering ig one paint would work on the Aluminum as well as the Glass.
jbcurt00
prep is different for the 2, but Rusto pro w/ enamel hardener can be shot on both aluminum & fiberglass
kjdunne
Post a pic of the shifter / throttle control. If it's a typical OMC side surface mount type, they can be configured to be mounted on either side. Easy to change over, can describe how to.
lokonn
Can tell you the resin work will go better with warmer weather. I did warm my resin and catalyst with halogen light for a bit before using and that seemed to help things. Becareful though with those lights. I set the epoxy on the cement floor, pointed the halogen at the floor and indirectly at epoxy. Didn't want to melt the bottles! The concrete got warm and the heat gently warmed the epoxy. Good luck.
