1978 Mercury 1400
murrayfish
Im trying to remove the exhaust leg. I seem to be stuck. What is next after these 6 nuts?
My whole aim is to pull the shift rod out of this motor and as far as I can tell I will have to pull the power head to do that. I bent the rod and wrecked the female spline in the motor on my boat. This is a parts motor...
murrayfish
So, I found out you can remove the shift rod by removing the scroll pin from the top of the shaft. But not before finding out there is 8 bolts not 6 that hold the power head in place.
Chris1956
Yes, you found the two bolts in the front underside of the motor, right? Your lower rubber mounts look loose. Are they?
