FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Is there any adjustment or limiter for the trim(not tilt) on the 800? mine will trim all the way up (bow) but will only trim down about 1/3 of the way. Battery has a full charge and there is nothing restricting the movement. Thanks
Not sure but I think it's going to be the motor. The jack screw look good and the solenoids are good. I did replace them as they looked to be original(1978). I guess I replace the motor. It only has a range of about 1/2 inch now.
Anyone know of a way to raise the screw with the motor or whatever not working correctly. I would like to get the bow down a little until I get the issue figured out.
Trim issue solved. I had a break in the signal wire. It would make contact with the engine down but as it raised it separated the wire just enough to break contact.
