1978 OMC 800 trim question
run2car
Is there any adjustment or limiter for the trim(not tilt) on the 800? mine will trim all the way up (bow) but will only trim down about 1/3 of the way. Battery has a full charge and there is nothing restricting the movement. Thanks
superbenk
Re: 1978 OMC 800 trim question
What makes you sure you're not obstructed internally? Might have some bad internal components, clearances or something else wrong inside the screw.
run2car
I meant nothing externally, not sure about inside. It is smooth as silk with the range it has and no binding noise.
run2car
Not sure but I think it's going to be the motor. The jack screw look good and the solenoids are good. I did replace them as they looked to be original(1978). I guess I replace the motor. It only has a range of about 1/2 inch now.
run2car
Anyone know of a way to raise the screw with the motor or whatever not working correctly. I would like to get the bow down a little until I get the issue figured out.
run2car
Trim issue solved. I had a break in the signal wire. It would make contact with the engine down but as it raised it separated the wire just enough to break contact.
