1978 V5 Holiday 18, 1988 Johnson 120
budski
Thanks Rob, yes quite a bit more challenging, but the hard parts done, got the rear end caps fabricated and transom cover moldings finished with diamond plate.
budski
Got the bow walkthrough and front deck supports built
Watermann
Nice support addition, good plan to add that when you don't have the center support that comes with the SS. That drop between the bow deck and base deck was too much for me on my SS so I added a step mid-way between the consoles.
budski
Going to add a storage hatch on both side and in front and a casting pedestal in the very front
budski
[No message]
Watermann
Nice work, nothing like adding to the functionality of stern area. :encouragement:
budski
Got the front and rear decks cut out and sealed with spar, 3 coats first with 1 part spar, 1 part boiled linseed oil, 2 parts mineral spirits, then 2 coats straight spar varnish, 1 more coat straight spar tomorrow then marine carpet.
FIGMO
Hey John,
the build is looking awesome, very inspiring!
I will be coming to see you probably in the next two weeks about vinyl, carpet and glue. I am super close to finishing the paint job on my boat, after that the vinyl and carpet.
budski
We got the front and rear decks secured.
Watermann
Moving right along there, you guys should have her water ready with a bit of summertime left. Sure made a more useful fishing boat out of the old Holly, way more valuable is it's current config over a closed bow run about.
FIGMO
Holy cow John, you guys work fast. I am more like molasses in January.
Looking sharp!
budski
That's for sure Rob, yes we're getting there Ron, but we've been working on it for a year so that's longer than usual.
budski
A bit more progress, getting the side panels fabricated and carpeted.
