scott hamilton
- Joined
- May 28, 2002
- 215
Re: 1979 18 ft Sylvan Skipper Rebuild
More pics of electrical.
I'm soldering wire splices and crimping ring terminals. Using adhesive lined shrink tubing. I ran 14 duplex wire to the fuse box behind the dash. Everything will run off that. I'm not really color coding. Blk is always ground on this boat and white/red will be 12VDC. Purple is 12VDC ignition. Blue is instrument lighting. I have green and tan for the temp sensors. I'm reusing some of the original wiring otherwise I would have just color coded everything properly. Not a huge deal to me.
I decided to leave the battery in the stern since a run of battery cable 40 ft long to go under tha floor costs an arm and leg. After reading up on the subject here and elsewhere it seems like a battery just belongs close to the starter motors and I don't want to think about heat under the floor while cranking on the old engine. Besides that this may help balance the weight of the kicker and bracket.
