1979 6hp Johnson cuts out.
Tronald
The motor runs really good, but when I'm tooling along WOT, it will just stop in it's tracks. This doesn't seem to be a fuel issue, and even if I use the prime bulb when it cuts out, it makes no difference. Any ideas??
Best regards
Tronald
Daviet
Re: 1979 6hp Johnson cuts out.
Have you checked spark when it quits? Is the engine overheating? How do you get it started again?
Tronald
No, I haven't checked spark when it cuts out, but I will do that. Once it quites, it takes about 10 minutes to get it started again. It spits out water really good and I did change the impeller.
Best regards,
Tronald
Tronald
So, if it has no spark, would it be safe to assume that it's the control module??
Tronald
