Theoutdoorsman
- Joined
- Mar 6, 2003
- 681
After returning to the ramp on my last outing, my tilt and trim stopped working. My service manual covers the t-n-t for this outboard, but I suspect the unit was installed on the outboard some time later, as it is a two wire harness instead of three wire, possibly early '80's. Long story short, I had to loosen the manual release valve to lift the outboard by hand to ready it for trailering. Once home, I discovered the fuse in the relay harness was blown. I now have two major problems.
And
If anyone can assist with these two issues, I'd be most grateful for your help in resolving them. Many thanks in advance!
1) I have no idea as to the size of this blown fuse. All writing has worn off, or is simply non-existent.
And
?2) the unit now has a masive trim fluid leak at the manual release valve after retightening. I found this out while testing. (bypassed the above mentioned blown fuse in the relay harness)
