Just purchased an 89' Glasstream Bass Boat with a 150 Johnson, 79' model. Compression is good 120,115,115,115, 115, 120, spark is good also will jump 1/2" or better. It will idle fairly well, every 5 seconds or so though, it will kick like its missing. New plugs same thing, I have the carb kits and a manual on the way, as I worked on an old '60 model 18hp and that helped but this is a different beast. Am I going in the right direction, and if the carb kits don't fix the problem what should be my next best move?
