115 1979 eninge runs rough at low speed occasionally skipping & sputters out unless i give it more gas. i have replaced thermostats and replaced fuel line. when running full throttle or 3/4 the engine runs fine. when i slowed up to go under 5 mph i smelled gas and then engine sputted out. i also noticed small gas leakage when i tilt engine up trickles out of gear/throttle cable holes. is it normal for gas to trickle out when engine is titled? Should i spray carb cleaner or can that be not such a good thing to do.
