198? V-4 omc gearcase. driveshaft crank splines are bad, will a V-6 driveshaft fit.
SparkieBoat
I have a 198? something V-4 gearcase. it is in great shape except the crank splines are messed up. I have a 20" and a 25" 198? something V-6 gearcases. They both have busted housings. will the dive shafts from these work? If so what about the shift shaft? They are different part numbers, but they appear to be identical. maybe I am missing something.
Thanks
Sparkie
Faztbullet
A V-4 shaft wont fit a V-6 case as the V-6 is longer from pinion to upper bearing......
Honorary Supreme Mariner
The bottom section of the V-6 driveshaft is quite " hefty " and this swap simply will not work.
SparkieBoat
Thanks a lot Faz and Racer, you surely saved me many hours of wasted labor. I really appreciate it.
Have a great day guys.
If anyone has a good used 20" V-4 driveshaft laying around that you could ship me for reasonable please PM me.
