1980 Evinrde 60hp gear box bad oil / seals?
alangranton
Hi, chaps, need some good advice.
I dropped the oil from my 1980 evinrude 60hp 2cyl
The result is a tub of white oil. I changed the oil ran in a barrel, same result see the pictures.
So i removed the propella and the rubber was squashed up in one side.
see pic below
I removed the lower unit for inspection.
the drive shaft seal was full of old mastic / sealant
that fell off.
The gearbox is not losing any oil and the gears work as they should.
Should I be concerned?
Should I replace the drive shaft seal or is it as it should be?
Should I replace water pump seals?
Any one got any advice.
Cheers Alan
jimdd810
Re: 1980 Evinrde 60hp gear box bad oil / seals?
It is definatley time for a reseal on the gear case and since you already havit off then you should invest in a new water pump as well. Water in the gearcase is a concern. Invest in a good factory manual and you should be able to do it your self.
alangranton
Any ideas where I can get a seal kit from. I'm struggling to find a supplier on the internet.
Many thanks Alan
jimdd810
you should be able to get the seal kit right here on i-boats. Go to brp.com and look up the parts there right down the numbers then come back to i boats
alangranton
Great found it, but what is a Mallory Seal Kit, Gear Housing?
:confused:
