alangranton
Thread starter- Joined
- Jun 7, 2010
- 31
Hi, chaps, need some good advice.
I dropped the oil from my 1980 evinrude 60hp 2cyl
The result is a tub of white oil. I changed the oil ran in a barrel, same result see the pictures.
So i removed the propella and the rubber was squashed up in one side.
see pic below
I removed the lower unit for inspection.
the drive shaft seal was full of old mastic / sealant
that fell off.
The gearbox is not losing any oil and the gears work as they should.
Should I be concerned?
Should I replace the drive shaft seal or is it as it should be?
Should I replace water pump seals?
Any one got any advice.
Cheers Alan
see pic below
that fell off.
Cheers Alan
