YoJoeySmacks
- Joined
- May 13, 2010
- 22
My trim motor went out. I attempting to remove the whole trim assembly from the motor. The motor is still mounted on the transom. I removed the three bolts on each side of the trim motor/power assembly which keep it afixed to the motor bracket. I removed both pins from the metal shaft rod that runs through the piston eyelet; however, the metal shaft rod is seized in there. I tried hitting it out with center punch/hammer,Freeze Off, PB Blast and even a propane torch. That thing will not move. Any suggestions? Does the Motor have to come off the transom? uggggggggggggggggg:mad-new:
