1981 60hp tilt trim unit?
white rat
Re: 1981 60hp tilt trim unit?
I'll try him but $450 is nuts, $550 get a new CMC plate up here so he'd have to move a bunch on a used unit.
The tilt unit came with the boat but I couldn't see how it would have the power to lift the boat while it was running, I also wondered if it was even a OMC part.
ACAMS, PM to you Mr.
Just because there isn't enough pics in this thread, here's the mini death trap I'm working on.
Bigjakes12
That is for the V4 .... it is not going to work on a 2 cylinder .......... What will you give me for mine?
OH CRAP....... I am in Texas ..... You are a few miles north of me!
Any chance you'd part with the pump? I replaced the motor & a hose & found the pump was toast. Toake maters worse, I tried to take it apart... Now I can't find a replacement.
Thanks,
Keith
white rat
Too small for a 70 triple and the mini voodoo was only rated for 20-40hp. Also the triples are 50+ lbs heavier than the 2 cylinders.
There are guys out there with 40hp going 50mph. I think in this case, smaller is better.
