Re: 1981 Evinrude 115hp multipe problem
I wasn't telling him not to rebuild the carbs. That would be a silly mistake to make on a motor that you have no past history on. But its pretty obvious when he said that he has "puffs" of smoke coming from behind the starter that there is a leak in the case! My leak wasn't even visable and my motor ran like crap. There is one bolt hole on the starter that goes all the way through the crankcase you might want to check and make sure all three bolts are there and tight as well. As soon as the carbs are done I would try and assertain the origin of the smoke behind the starter. Just my two cents.
