Hi Everyone,
I have posted here before about my 1981 evinrude 25hp having a powerhead gasket leak. I temporarily sealed that leak with some quick steel. The motor does not run with the cover on, it dies.
I also noticed this tube coming from the bottom of the carb and goes into somewhere behind and above the carb.
See pics.
The first pic is to show the position, you are looking at the port side of the motor, carb is to the right flywheel above left.
The second pic is the tube, it looks like it popped out of something because the clamp is still on it. you can see the carb behind it in this pic, but it looks like it went into something above/behind the carb.
2 questions:
1) Since the motor does not seem to run with the cover on, should I just pull the powerhead and replace the gasket?
2) What is this tube that leaks 2 stroke oil out and what does it go into?
This motor has been a challenge, but I am not giving up.
Motor runs fine with cover off, but runs 'bumpy' at idle.
Any advice?
Pics attached.
See pics.
2 questions:
Any advice?
Pics attached.
